Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crankshaft Balancing (a tough one)
Old 08-18-2010, 04:59 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Easiest way to figure this out is to spin it up with bob's that match the weight of the parts you are currently using, rather than some random published spec. If it has problems with your current bob weight, you can then correct it right then.
