Crankshaft Damper ("balancer") - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2007, 07:42 PM
TorqueJunky's Avatar
I noticed that the damper on my 383 SBC stroker motor was starting to get a slight wobble so I am replacing it before it gets worse or causes damage. When removing the crank bolt I will be using an impact and I want to know, is this bolt is not reverse threaded is it? Aslo I imagine I will I have to drain the oil before I start, but will I have to replace the front timing cover seal as well? This is a two piece timing cover if that matters...
Old 05-28-2007, 07:59 PM
engineczar's Avatar
The bolt is standard right hand thread. You don't need to drain the oil it won't be nearly as high as the seal. As far as replacing the seal it's tough to say without seeing it. It would be tough to change without removing the cover. Removing the cover means removing the water pump as well. (gaskets). If the seal doesn't leak now and it looks pretty flexible and is pretty recent I might consider leaving it. Your call there.
BSE Racing Engines
Old 05-30-2007, 02:22 PM
I just replaced a seal this week without removing the cover, but I had the radiator out so lots of room to work.
Crankshaft Damper - How to test if ok? leejoy Engine 2 05-14-2007 06:41 PM
The Crankshaft Sensor! 1988ChevyBeretta2.8 Engine 7 03-15-2007 06:05 PM
GEAR DRIVE = DAMPER PROBLEM bullheimer Engine 5 07-06-2006 12:09 PM
350 damper and snout questions Vortech 4.3 Engine 3 03-05-2006 08:03 AM
