Crankshaft internal vs external - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 10:07 AM
Just wondering what the difference is between the two crankshafts to make sure i ordered the right one...
Old 04-23-2010, 10:40 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
an external balance crank will have a flexplate/flywheel that has a weight welded onto it and must be balanced with it. an internal balance will not have the weight on the flywheel/flexplate. What engine is this for? also the harmonic balancer might have a chunk of material missing from it if its external balance
Old 04-23-2010, 10:49 AM
Its a 350 sb.. I will have to check the flywheel and balancer when i get home, Is it possible to go from an external to an internally balanced crankshaft?
Old 04-23-2010, 10:51 AM
Listen and Learn
Wiki Edits: 7
all sbc 350s from the factory were internal
Old 04-23-2010, 11:04 AM
Ok, thats good to know..
Old 04-23-2010, 11:11 AM
Listen and Learn
Wiki Edits: 7
all gen 1 sbc engines were internal except for the 400.
Old 04-23-2010, 12:45 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I know that the 454 BBC are externally balanced, too.
What about 502 BBC, are they also externally balanced?
Old 04-23-2010, 12:55 PM
The 350 is considered to be an internally balanced engine which is true for the cranks using the 2 piece rear seal basically pre 1986 production but also many current crate engines, so you have to check. The one piece seal 350 engines carry a small counterbalance at the rear externally because the rounding of the crank end to fit the seal took off a very small counterweight. Again you have to check to see if the intended flywheel or flexplate is equipped, if not there is an aftermarket part that bolts to the crank that brings the balance back.
So you just have to be careful when you start mixing parts.
Bogie
Internal vs. External Balance 68NovaSS Engine 17 06-12-2010 07:57 PM
Internal... External... Balance that 383!! KSailer77 Engine 8 06-09-2007 09:22 AM
Source for finding which ones are internal and external balance curtis73 Engine 3 11-10-2006 11:14 AM
external to internal voltage regulator TASHAN Electrical 2 09-04-2005 11:13 PM
Internal vs External Balance 614streets Engine 3 05-28-2003 02:25 PM
