Crankshaft Thrust Bearing Killer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2010, 01:24 AM
SSedan64's Avatar
http://www.youtube.com/watch?v=YEfqKoilLkI
Old 12-11-2011, 01:22 AM
Howdy Ssedan64! I Too Saw That Video On Youtube. As You Can See The Torque Converter Move Forward, It Is Not Ballooning As So Many People Have Said They Do. I Think This Situation Is Almost Always Just Over Pressure In The Torque Converter/cooler Feed. I Have Yet To See Or Hear Valid Evidence Of So Called Ballooning. Probable Causes Of Excess Pressure To Do This Would Be Torque Converter Internal Damage Or Trash, Restricted Cooler Or Lines, Or Too Great Of A Flow From Feed Circuit In Pump. Furthermore Since The Video Said He Had Already Replaced The Thrust Bearing In The Engine, What I See In This Video Is How Much The Flexplate Is Flexing!
Setting My Thrust Bearing and Clearance / Ford 289 coda618 Engine 3 05-26-2008 07:48 AM
Thrust Bearing Failure 123pugsy Engine 7 01-14-2007 06:26 PM
Thrust Bearing Wear 454impala69 Engine 14 07-04-2006 10:20 AM
Thrust Bearing HElp chumbucket Engine 1 04-28-2006 09:52 AM
Good article on thrust bearing failure and its causes. 4 Jaw Chuck Engine 1 03-11-2005 07:50 PM
