Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crankshaft won't turn by hand
Old 08-16-2012, 09:16 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
DO NOT smack any rods with a steel hammer,lol. Is this a trial fit of the parts? an engine is usually fitted a couple times,crank hand polished, you will need to or should check side to side clearance on rods, piston to wall should be individually checked,,etc,,, is this in any way a high performance engine?crank end play,,,
