Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crankshaft won't turn by hand
Old 08-17-2012, 11:26 AM
ryan v ryan v is offline
I also have a question about the pistons i'm using. I messed one up when i was putting it on the rod. So i ordered a new piston thats the same part number but where the wrist pin goes in it's different. The difference is that one has a full circle of raised material around it and the other only goes about 3/4's of the way around. Would this make a difference in the weight or will it run fine?
