Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crankshaft won't turn by hand
  #17 (permalink)
Old 08-17-2012, 04:50 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Originally Posted by ryan v View Post
I also have a question about the pistons i'm using. I messed one up when i was putting it on the rod. So i ordered a new piston thats the same part number but where the wrist pin goes in it's different. The difference is that one has a full circle of raised material around it and the other only goes about 3/4's of the way around. Would this make a difference in the weight or will it run fine?
I think this motor needs to go to the machine shop. First you mixed up a few rod caps, then you messed up a piston and replaced it with ?????How did you put the others on the rods? 20 ton press? Engine assembly is not rocket science, it is however technical. Most anyone can change a tire, but engine assembly? Best left to someone who knows what they are doing.
