Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crankshaft worry , now unsure of what to do with rod caps ??
Old 06-19-2012, 12:55 AM
jumbo2 jumbo2 is offline
Originally Posted by cobalt327
Engines I've done w/those same rods and bolts got 45 ft/lbs. Just like any other SBC w/stock 3/8" rod bolts.
You can use the 15 ft/lbs plus 70 degrees if you have access to the tool that shows degrees, I got mine at NAPA. It is kind of bulky so you may need an extension so it clears everything. The final choice is yours as to which method you use.
so I just loosen all rod bolts , then retorque all 8 to 45 ft lbs in any order and make sure there is lots of oil or just wet ? I need to do this and get motor back togther asap
