Crankshaft worry , now unsure of what to do with rod caps ??
Bought a used engine , guy said 383 bla bla bla so I took a gamble and when I got home tore it apart , everything was looking 100% until I dropped the pan and saw some color on the crank , so i pulled the rod cap to make sure it was fine and bearings and crank grind look perfect no wear or color , looks like at one time it spun a bearing so they ground the crank and re used it , crank is an eagle , pistons are probe flat top's and rods are unknown , I don't know what to do now ? Loosen all rods are re torque ? seen 45lbs with oil and 50lbs with lock tight ? bolts are 3/8 24 fine I believe
Because everything looks so good I was going to re torque the rods and run it , there is no way the crank would be colored and the bearings and rods be fine , im just unsure of what to do ? back all caps off and re torque all of them to ? ft lbs
Can you tell if the rod bolts are aftermarket? You might need a mirror to see the head side of the bolt. If we can determine what the bolts are then we can figure out a torque spec.
BSE Racing Engines |
IF you choose to reuse the rods as-is, I would retorque to stock specs. The reason is the bolts are knurled (not Waveloc), and the visible end does not have a dimple used to locate a stretch gauge. There are still knurled aftermarket rod bolts, and there may be knurled aftermarket rod bolts w/o a dimple for a stretch gauge, but my guess is those are stock. But if it was me, I would have to give some hard thought to pulling the rods and having ARP bolts installed, unless the cam/redline/ how the engine will be used is such that the stock rods and bolts are deemed to be enough. ![]() ![]() Note dimple ![]() PM rod on right. Note how the profile around the bolt on the rod and cap is smooth. You can compare this to yours. ![]() Side view, PM on right. Other side. Last edited by cobalt327; 06-12-2012 at 08:38 AM. |
Rod bolts have what looks like a capital I on the head , it's the out line of the I
Are you sure the pistons are forged? Are they stamped w/a part number and/or an oversize ID on the tops? |
so Yes they are 98 vortec rods , motor was a vortec and has had probe flat tops and eagle crank installed , only thing I could find was 15ft lbs then 70 deg on the rod bolts ?
Talked to eagle crank is fine to run |
Engines I've done w/those same rods and bolts got 45 ft/lbs. Just like any other SBC w/stock 3/8" rod bolts.
You can use the 15 ft/lbs plus 70 degrees if you have access to the tool that shows degrees, I got mine at NAPA. It is kind of bulky so you may need an extension so it clears everything. The final choice is yours as to which method you use. |
I don't know how much you wanted to inspect and measure, but you can plastigage the rod and mains for oil clearance as well as check the crank end float and rod side play before the pan goes on. |
It was a running motor so I don't think I need to worry too much , thanks for all your help :-)
| Rod main caps on backwards... what now? | ForceFed86 | Engine | 12 | 06-19-2010 12:01 PM |
| got an 84 riviera i am unsure what to do with. | fast68 | Hotrodders' Lounge | 10 | 04-01-2009 11:01 PM |
| Eagle rod caps | denno5644 | Engine | 8 | 04-29-2004 08:11 PM |
| Rod Caps | GearHead69 | Engine | 3 | 08-04-2003 09:38 PM |
| SBChevy Rod Caps appear mixed up | 360Camaro | Engine | 1 | 08-04-2003 07:46 PM |
