Crappy Air Compressor Wont work - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2005, 05:22 PM
rbfpezcore's Avatar
Not fast, but loud as hell
I bought a cheap air compressor because I wasn't looking to invest in something since i dont have much need for it. But when I turn it on, the motor runs, but i guess there is no compression going on? When i turn the valve to supply the hose with air I get nothing. Anyone had this problem before and if so, what did you do(Besides buy a decent compressor)?
Old 06-09-2005, 07:42 PM
Need more info-Do you have a gauge on this thing anywhere? Could be any one of a number of things and we need to know more about what it is and is not doing. If it is new maybe you can return it.
Old 06-09-2005, 08:50 PM
rbfpezcore's Avatar
I have two gauges on it and neither read anything when it starts up. It's past the return time, I have had it sitting in my garage for awhile. When I start it up, it sounds like the motor is working. The fan spins and what not, so it is getting power. But when I turn the valve to allow air to enter the hose, nothing comes out.
Old 06-09-2005, 09:04 PM
pumpkin35's Avatar
This may seem dumb, but....
Check and make sure that the drain plug is closed.
Old 06-10-2005, 01:10 AM
Does it have a belt?
Old 06-10-2005, 08:35 AM
72CutSupreme's Avatar
New Member
That was my next question. Its usualy fairly obviouse if a compressor is running. Their not tippically a quiet machine. So if the motor is turning the pump it should be fairly obviouse. If the motor is turning the pump then there is not tomany reason I can think that it would not be creating any pressure. No pistons in the pump? No rings on the pistons? A great big whole in the cylinder wall? Blown head gasket? In other words there must be somewhere that all the air is escaping to. feel around the compressor pump as it is running and see if you can feel all that missing air somewhere. Then see if you can fix the leak if you find one. Beyond this I have no idea.
Hope this helps.
Good luck
Dave
Old 06-10-2005, 09:03 PM
rbfpezcore's Avatar
Thanks for your help, but screw it, I'll just buy a real one.
Old 06-12-2005, 02:24 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
my ex got me a little coleman one that runs off 12v car juice, and I was camping and it took 30 minutes at least to fill my air matress. That was the first time I used it, maybe second.
The next time I used it it made no psi and made loud clunk-clunk-clunk noises plus the normal motor sound, minus the normal compressor sound. I guess I broke a con rod. It was made in china and it's from my ex, so I don't care.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
WillRam Air I ruin my performance? 67firebird Engine 6 11-16-2004 05:56 PM
K&N air filters may void warrantees. Jmark Engine 0 05-05-2004 10:40 PM
Air Ride for S-10 or use other? Andrew7dg Suspension - Brakes - Steering 4 05-01-2004 06:12 AM
