-   -   Crash Fuel Pump Shutoff (http://www.hotrodders.com/forum/crash-fuel-pump-shutoff-105114.html)
redsdad 12-23-2006 09:42 PM
Has anyone used one of these:
http://www.ronfrancis.com/accessories.htm
Item CR-92
Is there a less expensive alternative which will do the same thing?
67 Deuce 4 Me 12-23-2006 11:01 PM
Just go to the junk yard, find any later model ford and remove the inertia switch (fuel pump shut off). There on all the fuel injected fords as far as I know. It only uses 2 wires just wire it in series with the fuel pump power or ground ckt. They open the ckt when bumped hard or a crash etc.
Bryan59EC 12-24-2006 03:21 PM
That even looks like a late 80s ford switch.
I put one in the Elky from a 99 Taurus-----wired it thru the relay.
From the fuel pump relay coil ground--to the inertia switch---to a hidden on/off switch (anti theft) to ground.
2 screws and 2 wires-----EZ
Bryan
