Crash Fuel Pump Shutoff - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2006, 09:42 PM
Will I ever get it done?
Last journal entry: Hood
Has anyone used one of these:
http://www.ronfrancis.com/accessories.htm
Item CR-92
Is there a less expensive alternative which will do the same thing?
Old 12-23-2006, 11:01 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Just go to the junk yard, find any later model ford and remove the inertia switch (fuel pump shut off). There on all the fuel injected fords as far as I know. It only uses 2 wires just wire it in series with the fuel pump power or ground ckt. They open the ckt when bumped hard or a crash etc.
Old 12-24-2006, 03:21 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
That even looks like a late 80s ford switch.
I put one in the Elky from a 99 Taurus-----wired it thru the relay.
From the fuel pump relay coil ground--to the inertia switch---to a hidden on/off switch (anti theft) to ground.
2 screws and 2 wires-----EZ
Bryan
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
Nitrous Problem, Maybe fuel pump? esears Engine 7 05-02-2005 05:21 AM
93 dodge shadow fuel pump repair junkie Electrical 2 10-02-2003 08:05 AM
