Crate engine ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 07:27 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
Crate engine ID
Yes I searched all the Chevy ID sites.I would like to identify a Cheve small block I purchased from a co-worker.The engine has "hecho en Mexico"cast over the casting #on the rear of the block.so I know it is a replacement engine. The casting # is 10066036,stamped# on front boss is 1m0505,below that is stamped 7vp.The block is set up for either right or left side dipstick,and has very small heads on the head bolts(13mm).
Old 04-14-2008, 09:19 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
350, 2 or 4 bolt mains, 2 piece rear main seal. Yep, Mexico made.
http://www.mortec.com/castnum.htm
Semper Fi
Crate Engine Operating Temperature HotRodMan Engine 6 10-15-2006 10:43 PM
Yearone crate engine Piston1 Engine 2 01-28-2006 02:24 PM
350 crate engine into 53 Oldsmobile jerseymeathook Engine 5 01-10-2005 10:42 PM
350 crate engine Seon Engine 2 11-13-2002 06:58 PM
Chevy Crate Engine Numbers? Slam63 Engine 0 10-15-2002 12:34 PM
