Crate Motor Delima Plz Help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 08:50 AM
I just recently bought a GM Performance crate engine For my 78 Camaro circle track car. Part number NAL-88958602. Its the one set up for circle track racing. Ive got it installed, and now starting to put accessories on it, and there is a small plug in the hole where the Oil Dipstick goes. Ive tried to pry it out but it doesnt budge. I dont want to push it in cause then i would have to drop the oil pan, and its already in the car. If anyone knows how to remove it please help. Just to give you an idea it looks like an aluminum seal on a tube of gasket sealant. However it is much thicker.
PlZ Help..
Fox
Old 08-06-2007, 09:01 AM
PlZ Help..
Fox
Typically competition only engines don't use dip sticks because of oil leakage past (read that gusher) them at high revs. So this passage is normally sealed with a plug on the Crate motor you selected.
The only way to remove these plugs is to dill it out. This means the pan comes off to insure chips aren't in the pan and crankcase.
Bogie
Old 08-06-2007, 09:20 AM
So...
It has an eight quart oil pan but im sure it needs a little more. How do i check to make sure it has enough oil for racing?
Old 08-06-2007, 09:57 AM
Holder350's Avatar
Auto Parts Professional
Drain it out in a VERY clean pan and measure it back in.
Old 08-06-2007, 09:58 AM
There should be a sight plug in the pan, rather like that used by motorcycles (other than Harley).
Frankly I'm not keen on these factory sealed race engines unless the rules dictate their use. Old fashion type of a guy, I don't trust anything, I haven't built.
Bogie
Old 08-06-2007, 10:34 AM
thanx
It hasnt had the first drop of oil put in it yet...Well that explains what the plug on top of the oil pan is for.. You've been alot of help...Thanx
Old 08-06-2007, 10:36 AM
Yeah, just wait till you have to see what's in there!
Bogie
Old 08-06-2007, 10:41 AM
confused
What do you mean? See whats in there?
Old 08-06-2007, 10:42 AM
Oil level, there should be a sight plug thru which you can see the oil level. Easy to do in the shop, not so much fun in the pits with a trouble light.
Bogie
Old 08-06-2007, 10:48 AM
engineczar's Avatar
I would put in the 8 quarts. Remember the pickup is in the bottom of the pan. Having a half quart low is better than a half quart high.
BSE Racing Engines
Old 08-06-2007, 11:11 AM
yeah you guys are telling the truth.
CRATE ENGINES...Are they worth it? Theeis Engine 5 06-20-2006 02:06 PM
Goodwrench Crate 350 pros/cons redsdad Engine 5 11-11-2004 11:48 PM
To Crate Motor or not to Crate Motor wickster Engine 2 09-15-2004 10:49 AM
350 crate hp add ons blue85 Engine 15 11-19-2003 11:19 PM
GMPP CRATE MOTOR Intake Manifold Vacuum alligator Engine 6 09-18-2002 07:02 PM
