crate motor info - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2012, 04:03 PM
crate motor info
swooped a great deal on a fresh GM crate 305 searching stamped numbers on block no luck numbers are as followed T1052551 and V0017PZ , head numbers 14102187. Any help or location would be great
Ken
Old 01-25-2012, 04:48 PM
DoubleVision's Avatar
PZ 78 305 Pontiac 145 LG-3 TH 350 2-Brl Hyd Cam
14102187 305 87-95 1.84/1.50 58cc
THe heads are going to be of the swirl port variety which work excellant for low end torque, but they run out of breath at 4000 RPM.
Old 01-25-2012, 05:13 PM
crate motor
hey thanks for the info, only have a couple hundred in the new crate motor so it will be a everyday driver with a th350 and a 273 10bolt
Old 01-25-2012, 09:14 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
IF i may ask wht was the deal. How much and from where?
Old 01-26-2012, 09:17 AM
deal and where
coffee shop talk, 200
Old 01-26-2012, 09:43 AM
sum'itch! thats a good deal!
Nicely done Sir
Old 01-28-2012, 08:19 PM
rear main oil seal
didnt one piece come out in 85/86? my engine has a one piece rear seal
Old 01-29-2012, 01:21 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
1986 now need to add to post to make it at least 10 letters.. HA
HO 350ci 350 crate motor info trog Engine 9 01-22-2011 03:23 AM
`Crate engine casting no. Info. pepegriffo Engine 1 12-01-2009 02:43 AM
RHS Crate Engine Info Needed JackFlack Engine 2 12-03-2008 01:19 PM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 08:15 PM
crate engine info blue85 Engine 0 11-19-2003 01:48 PM
