#1
I hear of people paying prices that range all over for a Small Blk Chev crate motor. I'm looking for a basic 4 bolt(250hp) & was wondering what kind of prices are you guess paying OR do you have a better idea........Don
| Sponsored Links |
Register now (free) or login to remove ads |
#2
The following link as numerous crate engines from Chevy.
They range from $1300.00 to just about anything your heart desires. http://www.greenwoodchevy.com/specials.htm These are all GM crate engines and by reputation are pretty well assembled. |
#3
goodwrench 350 price is 1480 USD. figure arround 500 on accessories, specs below.also if you want a little more power it is actually cheaper to buy this engine and then substitute parts than it is to put one together yourself
Engine Name: 350 LM1 Horsepower: 249 HP @ 5,000 RPM RPM Torque: 304 Ft/Lbs @ 3,500 RPM Compression Ratio: 8.50 to 1 Block: 4 – Bolt, 2 Piece Rear Seal, 4.000” Bore Crankshaft: Cast Nodular 3.480” Stroke Heads: Cast Iron, 72cc Valves: 1.940” / 1.600” Camshaft lift: 0.390” / 0.410” Hydraulic Duration @ 0.050”: 195° / 202° Intake: Not Included |
