KA67 does it have a Mercruiser tag on the side of the bell housing flange? Depending on where he bought it, it could have had the intake changed from the stock unit. Most of the fuel injected marine engines, except the high hp models, got the small oval port heads to aid bottom and midrange torque. Check my thread on the differences between automotive and marine engines if you are planning on running this in an automotive application.
I'll check for a tag when I get home. The plan is to put a pair of turbos on it, buy some bigger injectors, have the computer reprogrammed and build my 72 Chevelle around it. I guess I'll be swapping out the heads. I have an extra set of large oval ports but would prefer rectangular. I only have $2500 in motor so far, so I may purchase some aftermarket heads.
Thanks, Kevin |
If you plan on running turbos, I would recommend the AFR 305cc heads with the CNC ported combustion chambers. If you had the money, I would go with the fully ported 315cc heads. It sounds like a cool buildup.
Adam |
There's no tag on the back of the motor. There is a small cut off piece of flat steel with one bolt going into the back of the head. It looks like it was there to hold a hose or something, but could have been a tag. Are some mercruisers shipped with ASM intakes?
Kevin |
It is my understanding (according to Mercruiser) that all engines from mercruiser have the metal tag on the block held on by rivets. I have heard of these engines offered through some marine retailers fitted with the ASM intake system. Other than that, I can't give you any more info, sorry. I'd be happy to shoot you a price on some heads if you're interested. Let me know.
I have to wait for a super deal (almost free) before I buy some heads. I'd love some huge AFR's but they don't come cheap enough. I'm watching some small merlins in need of repair right now. Thanks for the info.
Kevin |
| Squeezing a little more power out of my 454 | RObs71Nova | Engine | 8 | 05-21-2005 03:38 PM |
| 454 engine swap | Hot_Rod_Faith | Engine | 1 | 01-15-2004 02:30 PM |
| 454 or 427 for 70 Chevelle? | f100beatertruck | Engine | 3 | 11-25-2003 05:29 PM |
| Seems Best way to Buy a 454 BB is to Buy a Truck | Auto-Part | Engine | 3 | 11-15-2003 04:23 AM |
| GM 454 Crate Motor | Dub Oldham | Engine | 7 | 11-14-2003 08:56 AM |
