Crazy Idea. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2011, 08:59 PM
DoubleVision's Avatar
Crazy Idea.
I have a 1992 chevy silverado with a 4.3 V6 and a 5 speed tranny.
I have the standard instrument cluster, speedo, temp, oil, volts, etc.
I was able to get a Cluster with a tachometer, however, it`s only set up for the V8 unit and the factory didn`t leave the provision for the 6 cylinder unit.
But I was thinking, is there something that can go inline to adjust the signal to work with the 6 cylinder? Crazy Idea, but I`m not big on electrical. Right now I have a small tach mounted in the cd case cavity in the dash above the vent controls. Even so it`s hidden from view and it don`t look bad, I would still rather have a dedicated factory tach. Appreciate any suggestions.
Old 10-15-2011, 10:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Might be something here you can use
http://www.howtoalmanac.com/kevin/pr...ve/tachfix.htm
http://www.thirdgen.org/techboard/el...h-v8-tach.html
http://www.s-series.org/htm/how2/recalibr.htm
What did you decide on that HG?
Crazy Idea. DoubleVision Suspension - Brakes - Steering 1 03-08-2011 08:10 AM
crazy idea cjskustoms Introduce Yourself 1 09-02-2006 09:37 PM
crazy idea... crazy larry Hotrodders' Lounge 10 09-16-2003 09:50 PM
Crazy Idea? Kaylah Hotrodders Site Suggestions and Help 4 09-10-2003 07:35 AM
crazy idea racecargurl Body - Exterior 18 01-24-2003 11:17 AM
