CRC Parts Washer Solvent vs. Berryman's Chem Dip - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2011, 12:04 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hi All,
I am interested in buying a five-gallon bucket of parts cleaner for dipping carburetor parts and such. The two that I've found are the Berryman's Chemp-Dip / B-9 Cold Parts Cleaner and the CRC Parts washer Solvent.
I have used Berryman's before and it worked great, but it is quite expensive. The cheapest 5 gallon I found is about $115 shipped from a not-so-well known-website. Other wise its roughly $140. The CRC Solvent is available locally for about $85. However, I have not seen any reviews for it. And I could be wrong, but I think the CRC solvent is for parts washer machines.
I wanted to ask if any members here have used the CRC stuff and what they think of it. If it comes down to it that the CRC solvent won't cut it (pun intended), then I'll spend the extra money on the Chem Dip.
Or if you have a suggestion for a better product at a reasonable price, I am open to that as well.
Thanks in advance!
Old 12-24-2011, 03:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Very different solvents. The Barrymans has methylene chloride as the main ingredient (at least it did in '06) and when used on carbs, etc. there's little out there that does a better job. Limiting your exposure is highly recommended. The parts washer solvent is something akin to mineral spirits.
MSDS tells the stories-
B-9: http://www.berrymanproducts.com/Port...01,%200905.pdf
CRC: http://www.crcindustries.com/faxdocs/msds/5067.pdf
Mineral spirits: http://megaloid.ca/MSDS/Mineral%20Spirits.pdf
Old 12-27-2011, 11:29 AM
Wiki Edits: 132
Got it. Glad I asked before going with the local offering. I'll spend the extra money and stick with what works. Thanks Cobalt!
Old 12-27-2011, 11:39 AM
Considering the expense of the Barryman's, clean the parts with a cheaper solvent first. then let the Barryman's do the hard work.
Wear protective gloves, and a face shield with either.
berryman's chem dip, chemicals, crc, parts solvent, parts washer
Tip from a buddy on using Varsol or other similar parts washer solvent donbryce Garage - Tools 7 10-19-2011 07:56 PM
parts washer richardson110 Garage - Tools 3 06-15-2008 02:36 PM
Parts Washer - To have or have not!?? 11echo Garage - Tools 3 01-31-2008 03:09 PM
water based washer solvent for parts washer 62CHEVYC10 Garage - Tools 31 02-03-2007 06:09 AM
Parts Washer Solvent? iiibdsiil Garage - Tools 18 01-06-2005 08:00 PM
