Creating NEW t-bucket frame plans - Need TONS of info, plans & measurements - HELP! - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 01-29-2006, 03:40 AM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
bump, just cause veryones replies keep me working toward the goal
  #47 (permalink)
Old 01-30-2006, 07:18 AM
T bucket plans
There are a number of plan sets around, as you say, LoRollerChevy. CCR's sets have been around a long time, and for about $25, you can buy them. They have some oddball characteristics, among them the front spring mount, which many think is "upside down."
Car Craft may have been the magazine somebody mentioned earlier, back in the '70's. Lots of T's were built with those plans. The one characteristic that sticks out about that set is the two large coil springs for the front spring. Any car with that was probably built in that era, from those plans. I have a copy of those plans, myself.
Chester G's plan book comes up regularly on e-bay, but since it's been out of print for a long time, it usually bids up well over $100. And, again, it has some oddball ideas that probably were great at the time.
I'm the VP of the National T Bucket Alliance (www.nationaltbucketalliance.com), and I'm all for spreading the knowledge of these little cars that are about as much fun as you can have with all your clothes on. They're simple. Heck, the previous VP built his car at 15, with a frame constructed from the steel from a John Deere tractor's roll bar, the steering gear from one of the ranch's combines, and an engine, transmission, and rear end from a dirt-cheap '64 Bel-Aire. He's still driving the car, has almost 300,000 miles on it.
We have at least one member who builds frames and sells them pretty reasonably. But anyone with a decent welder and a modicum of skill can build a T from scratch, by eye. They're not complicated. In fact, they're about as basic as you can get; a frame, engine, transmission, rear end, steering system, cooling system, brake system, and somewhere to sit, and you're there.
  #48 (permalink)
Old 01-31-2006, 09:10 PM
Wiki Edits: 22
frame plans for sparky, still have a load to do before they realy get any text ...
  #49 (permalink)
Old 02-10-2006, 04:07 PM
Wiki Edits: 22
bump cause i just realized that Jon put this thread on the forum front page
  #50 (permalink)
Old 02-10-2006, 10:47 PM
jalopy45's Avatar
This may be some help, "HOW TO BUILD A HOT ROD SERIES"," CAR CRAFT" T BUCKET. Complete 9 Part Series CAR CRAFT Nov 64 thru July 65. This would be considered public domain and has plans for all the pieces and assembly tips. It used Corvair springs for suspension and if I remember right it even had plans for the dropped axle,tie rods and radius rods.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
  #51 (permalink)
Old 02-11-2006, 02:43 PM
Wiki Edits: 22
today a package arrived, from JD in kansas city ...
30 some odd pages of car craft magazine from the summer of 67 ... "street roadster in kit form"
one cool thing i noticed while glancing thru is they used corvair coil springs for thje rear suspension, and fabricated top and bottom buckets for them
one of the pages even has all the dimensions needed to built a motor mount plate for the FRONT of the block designed so that it dips under the crank and allows you to do any engine servive you need and not get in the way
  #52 (permalink)
Old 02-11-2006, 08:14 PM
Wiki Edits: 22
engine plate
Name:	engine mount.jpg
  #53 (permalink)
Old 02-12-2006, 01:53 AM
Wiki Edits: 22
engine plate continued
Name:	engine mount plans .jpg
  #54 (permalink)
Old 02-12-2006, 10:15 AM
Chopt 48's Avatar
I used plans from one of those magazines to build my first T bucket frame in the early 70's. It used the Corvair front springs for rear springs An easy to do setup. The springs were pretty inexpensive new at the auto parts store at that time. I made a track bar setup that worked but left a bit to be desired.
One thing to remember when building a T frame from rectangular tubing. Make sure that you put the weld seams on the tubing to the inside as that seam always wants to through your paint on the frame.
I think I used 60 degrees as the angles on the kick up (that was 33 years ago and I may be wrong) and by a bit of dilligent planning and measuring I was able to get most of the frame out of one stick of tubing. If you have to "cut to haul" Know your needed measurements so you can have the steel yard make the cut where it will give you the least waste.
  #55 (permalink)
Old 02-12-2006, 10:18 AM
Chopt 48's Avatar
OOps I hit quote instead of edit
The great thing about T bucket frames is that there is no absolute It has to be exactly this way criteria. wheel bases are adjustable to suit the individual and dimensions can vary to fit different parts combos.
I had a 108 inch wheel base on mine but most of the t's at the time were on 98 inch wheel bases.
  #56 (permalink)
Old 02-16-2006, 10:57 PM
Wiki Edits: 22
some hairpin brackets ...
ID:	10091   Click image for larger version
  #57 (permalink)
Old 02-18-2006, 06:08 PM
Chopt 48's Avatar
I'm not positive but I Think someone with an engineering background would tell you that the sharp corners in the windows in the brackets could be a possible spot for a stress crack to start. It sure looks nice but will it hold up to the rigors of running down the road.
  #58 (permalink)
Old 02-18-2006, 06:29 PM
Wiki Edits: 22
yea, they would be, ive already redrawn it so they are all rounded corners
  #59 (permalink)
Old 02-18-2006, 11:06 PM
Wiki Edits: 22
heres the updated bracket, with 1" radius's around the back, forget what the radius is on the cut outs tho ...
  #60 (permalink)
Old 02-18-2006, 11:53 PM
Chopt 48's Avatar
That even has a smoother look to it. Very Clean.
'23 t bucket frame plans??? dorksrock Hotrodding Basics 14 07-19-2009 08:28 PM
T Bucket Steering and Radius rods plans ken47 Suspension - Brakes - Steering 11 02-01-2007 06:39 PM
Frame Swapping Info needed TexasHardcore General Rodding Tech 8 07-05-2006 11:17 PM
