Creative Ways of Attaching Door Panels - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-08-2007, 10:19 AM
What's wrong with panel clips, for crying out loud? You can't see them (one of your requirements not met by any screw or button covered screw), they hold like crazy (another requirement you and we all like), they're easy to install and remove(with the right tool) (another requirement done), they're just as cheap a thing as you can get (the most often asked for requirement for any car project), AND, how many times does anyone ever remove their door panels in any lifetime anyway?
Sometimes there just isn't a box to think outside of, yaknowhatimean?
  #17 (permalink)
Old 02-08-2007, 10:47 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I totally agree with Pasadenahotrod. The other problem with velcro is the self stick kind will fail in high temperature settings. I suppose the velcro could be pop riveted too, but that seems like a lot of extra work for nothing. They do make a velcro called "Super Adhesive" that will stand up to high temp, but it's extremely expensive, $4.50 a yard for one side only. The button coverings that were talked about are called Dura-Snap buttons, but they only come in size 30 and 36 (about 3/4" and 7/8") which would be pretty big on a door panel. Why don't you like metal door panel clips, Alan? (I agree that the plastic ones suck.) I use Au-ve-co #10780 offset trim fasteners. Lay out the holes on the door and mark the same position on the door panel. Then I punch or drill a 1/2" hole in the same position 5/8" away from the outside edge of the panel. This way you upholster the panel and then hook the clips in the holes in the panel afterward. It makes upholstering the panel easier because you don't have the clips in the way, and they are extremely easy to adjust this way which makes attaching the door panel much easier. Another benefit is that the holes in the panel are farther away from the outside edge which makes a stronger panel.
  #18 (permalink)
Old 02-08-2007, 02:13 PM
302 Z28's Avatar
Panel clips can be a bit of a challenge to hide when you are trying to keep the door panel as thin as possible. 1/8" Luan or ABS plus 1/8" closed cell foam padding covered with leather.
Vince
  #19 (permalink)
Old 02-08-2007, 02:39 PM
FASTFORD's Avatar
go to Wally World & purchase packs of Velcro...pick up some Gorilla glue.... glue 4" long Velcro strips every 12 inches to panels & inside doors in corresponding locations....job done.
don't ask me how i know.....
  #20 (permalink)
Old 02-08-2007, 03:28 PM
Vini Vidi Vici
Don't use velcro. Use door panel clipse, and if you want them to disappear for a thin application, counter sink them. Just when removing the panel, use a proper tool and don't just yank on the board.
  #21 (permalink)
Old 02-08-2007, 04:55 PM
Wiki Edits: 22
Should I also assemble car seats using Gorilla glue and velcro instead of sewing them? If Velcro and Gorilla glue was the best way to attach a door panel, don't you think that the car manufacturers would use it? Why is that? Because it takes way more time, effort, and money to attach them that way. Why would you want to spend $20.00 to attach a door panel when you could attach it for $2.00?
  #22 (permalink)
Old 02-08-2007, 08:40 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
The main thing that bugs me is lining them up. Aside from the plastic ones (which is probably why I'm over-reacting), I've only tried Au-ve-co #11406 (old school). I'm not familiar with #10780.
How many do you use on a typical panel, Dan?
  #23 (permalink)
Old 02-09-2007, 06:20 AM
Originally Posted by horvath
The main thing that bugs me is lining them up. How many do you use on a typical panel, Dan?
Make your door panel and hang it where you want it with a couple self tapping screws and drill 1/8" holes through the panel and door where you want clips. That's the center mark for your clips. Then go back and drill 1/4" holes in your door. I like to put them about 6" appart. Check the door before you drill. There are some places where you can't put clips.
Bob
  #24 (permalink)
Old 02-09-2007, 06:54 AM
brian0605's Avatar
mostly confused
Last journal entry:
Did you read the title for this post? It says creative ways to install door panels. Not ways to install door panels like they have been doing for the last 75 years. Now with that said, I personally wouldn't worry about it to much and would probably use the plastic clips. I'm not going to tell someone there wrong over something this trivial. It's his build/project and he can do it however he wishes. And Dan Two lakes, no one said anything about assembling seats with the stuff, and apparently you haven't taken any late model seat apart.They are using Velcro on certain parts of the seat upholstery. I don't understand why ya'll have to be so critical over this,it's not like we suggested velcroing down a new 650 demon to the manifold. Brian
  #25 (permalink)
Old 02-09-2007, 07:39 AM
Wiki Edits: 22
You are correct, the title of the thread is creative ways to attach door panels. My point was and still is this: You can come up with thousands of ways to attach door panels using everything under the sun to attach them with but sometimes what has worked for 75 years is still the best way to do something. Yes, I have taken apart late model seats, and they use Velcro or Velstick in place of the wires and hogrings that have been used forever, and it works great. I never said that old ways can't be improved upon, and I'm sorry if I upset anyone with my comments.
To answer your question, Alan, Bob C is right on. 6" apart is a good guideline. If you use the offset clips, they can be turned in their holes slightly and lined up with the holes in the door as you go. This way the clip position isn't as critical, and you don't have to deal with the clips when you are upholstering the door panel.
  #26 (permalink)
Old 02-09-2007, 08:16 AM
horvath's Avatar
Thanks, one and all - you've all been very helpful and I appreciate it.
The Au-ve-co clip #10780 is pretty similar to #11406 ... either way, you sandwich them, right?
Here's #10780:
Here's #11406:
But the #10780 looks like it may slide in from the side and hug the edge of the panel ... is that right?
  #27 (permalink)
Old 02-09-2007, 09:50 AM
Yes
No, punch a hole in the door panel and slide them in. Look at an original door panel to see how it's done
I use #2385 for steel doors and #10780 for fiberglass. The nice thing about them is if you damage a clip it can easily be changed.
Bob
  #28 (permalink)
Old 02-09-2007, 10:02 AM
horvath's Avatar
Thanks!
What's the difference between #2385 & #10780? I get a "no find" at Au-ve-co for #2385 and I have steel doors.
  #29 (permalink)
Old 02-09-2007, 10:46 AM
Wiki Edits: 22
The 11406 is a straight clip, not offset. That clip would have to be in the panel when you upholster it because the head of the clip is directly over the shank of the clip, and the diameter of the hole in the panel would have to be be smaller so the head of the clip doesn't pull through the panel. The other two clips are almost exactly the same. They are both offset clips, but the 10780 is a little longer, which would make them better for fiberglass doors, and the 2385 are shorter ones which would be better for steel doors. You slide the top of the clip into a 1/2" hole in the panel that is offset 5/8" to the inside of the hole in the door. In other words......the shank of the offset clip is directly over the 1/4" hole in the door, but the head of the offset clip is more to the inside. Because the hole in the panel is 1/2" in diameter, you slide the clips into the panel right before you attach the panel. I like the 10780 for all doors, but that's a personal preference. 1720 clips are almost identical to 2385 clips. Don't glue your padding material real closely around the 1/2" holes in the panel so the clips can be moved slightly as you attach the panel to the door.
  #30 (permalink)
Old 02-09-2007, 02:11 PM
brian0605's Avatar
mostly confused
Last journal entry:
Look the whole reason I got my panties in a twist was the fact that people were "POO POO 'ing " all over the idea of Velcro. It would be an easy way to install. No holes to drill, no worry about making sure the clips were lined up etc etc etc..........If that is not YOUR preference fine just say that and tell how you would in stall it. Maybe I'm just being to sensitive, I'll just go take some PAMPRIN or MIDOL and go take a nap....... No harm No foul.Brian
