Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - crinkle spots in base coat
Old 05-09-2013, 09:17 PM
MARTINSR MARTINSR is offline
It likely happened because the sealer was too thin, so the solvents from the chromabase went thru it, lifting it off the substrate. Or it was too thick, and didn't fully flash off so it was soft and the same thing happened, solvents from the chromabase went thru it.
The other option is that the substrate wasn't sanded properly and the sealer wasn't adhered to it so the solvent from the chromabase went under it.
