Critique my combo please...
90-91 454 w/.030 over bore
TRW L2307af forged pistons heads are GM casting 6272292 w/2.06 / 1.71 small valves GM cast crank GM truck rods, shotpeened, polished w/ARP bolts Isky Mega 292 hyd cam Edelbrock RPM intake Holley 850 dp Motor is for a 71 weekend only street/strip Chevelle. With this piston/head combo should be around 12.1 cr using race gas. Upgrading to larger 2.19/1/88 valves in heads. Would like between 500-550 hp to move this car into the 11's. I would like to use the parts I have however if you see something which is mismatched, please advise. Let me see your similar combos and hp results. Thanks ! |
Ok, I have changed my plan a little....
90 454 w/.030 over bore Sealed Power L2465 forged pistons 9.6 cr w/ 781 heads heads are GM casting 781 with 2.19/1.88 valves, light bowl blend GM cast crank GM truck rods, shotpeened, polished w/ARP bolts Edelbrock RPM intake Holley 850 dp which cam Isky Mega 292 hyd or Lunati Voodoo 60204 ? any guess on hp ?? trying for just close to or just over 500 hp |
need gear and converter specs, weight of car to help with cam choice...
71 Chevelle, 3.73 posi, tci 3000 converter, probably 3800 lbs w/me.
| critique the final combo | WsXs3 | Engine | 3 | 01-10-2006 01:20 PM |
| Please critique my combo | 1985fiero | Engine | 13 | 06-17-2005 09:06 PM |
| Please Critique Cam and Combo for 383 | Chevy21 | Engine | 7 | 04-01-2005 12:50 AM |
| 406 critique my combo please!!! | HoosierDaddy | Engine | 22 | 02-17-2005 07:53 PM |
| Critique my SBC 400 Combo | DTL504 | Engine | 24 | 11-30-2003 05:37 PM |
