that looks really good !!! i may be followiing your foot steps here soon.....when you did the interior cross bracing did you beef up the inside of the boxed frame where the tubing is welded to the "interior new side of the frame"? I can't imgine the center part of your frame twisting with that set up.
Yeah, I beefed it up a bit. If you look in the first pic, you can see the bolt heads on the outside of the frame. Notice everywhere the tubing meets the frame, I beefed it up by bolting a steel bushing between both sides of the frame wall, that way if it trys to flex it will have to move both walls of the frame. That should help strengthen my welds in those areas also. Then,,I put the piping right over the bolt head on the inside of the frame and welded the piping to the frame, that way it still looks somewhat smooth on the inside and you can't see those ugly bolts sticking out of my inside frame rail
i like that idea, what did you do for the bushing? just piping or tubing cut to size? and then when you cinched the bolt down it compressed the two sides together....did you cinch it down before or after you welded the plates for boxing the frame...how many feet of tubing did you wind up buying for this and where did you get it. thanks bob |
Actually, it was an idea that I thought of after the frame was boxed. I did it because of the distance between crossmembers and I was afraid the center of the plate would flex with all the tubing welded to it possibly making my box plate welds weak. I drilled a hole in the frame and a hole in the box plate. The one in the frame had to be slightly bigger so I could slide the bushing in between, then simply put a washer on the outside bolt head to compensate for the larger hole (otherwise the bolt would just bottom out on the bushing). For the bolts I wanted something strong so I used grade 5 bolts approx. the size of your index finger, and found some steel tubing the same size. The only tubing I could find around the shop for bushings was slightly smaller than the bolt so I cut the tubing to length (magically transforming it from tubing into bushing
thanks. sorry for my poorly worded question what i meant was how many feet of tubing did you wind up using to box the frame? and where did you get it thanks bob
I don't remember exactly how many feet I got. I think they were all 3' lengths and I cut them to fit. What I did was used 1" plastic (pvc) pipe to mock the whole thing up. That way if I didn't like how it looked or needed to make a change it was as simple as cutting plastic pipe with a hacksaw
They say that the triangle is the strongest shape, at least in architecture.
So... I think it's good. But I don't know much regarding frame/chassis design. |
Looks like it will be quite solid |
Looking great SG, what body is going on it? Mike |
It's going to be a '50's pickup. So far I've chopped the top 5 1/2" ,chopped the doors and suicided the doors
| 59 Chevy pickup frame woes! | Li'l Pine | Suspension - Brakes - Steering | 33 | 07-08-2009 08:24 PM |
| 86 s-10 frame bent | catscan4free | Suspension - Brakes - Steering | 3 | 03-27-2007 09:46 PM |
| Cantilever system for air bags | 53LEDSLED | Suspension - Brakes - Steering | 17 | 12-05-2004 03:26 PM |
| 57 chevy frame alignment question... please help! | Sanspants | Suspension - Brakes - Steering | 1 | 07-20-2004 10:15 AM |
| Body & Frame question | ruiner808 | General Rodding Tech | 7 | 09-14-2003 05:54 AM |
