crome - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2004, 09:36 AM
crome
what is the best way to bring back the polish to the trim and my bumpers on my truck it is a 78 chevy short box
Old 04-28-2004, 10:51 AM
Member at Large
I've used fine steel wool and polished the s*&t out of it. That worked as long as it is not damaged, or rusted. Also heard a myth of aluminum foil and Coca Cola......not sure how that worked
Old 04-28-2004, 11:14 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Aluminum foil and water works, I've done it.
Hey 78 Chevy truck, you put this in the right forum, good for you!
Old 04-28-2004, 11:29 AM
badriand's Avatar
what is the foil and water trick? Just scrub the H*#@ out of it with the foil while applying water?
Old 04-28-2004, 11:58 AM
willys36@aol.com's Avatar
Wiki Edits: 21
If it has those little dark pinhead sized 'warts' on it, use Dupont #7 polishing compound then Mothers mag/chrome polish. Those warts are rust welling up through microscopic pores in the chrome and the aggressive #7 will take them totally off. Mothers should restore the shine. Finally, I maintain all my chrome with good old liquid Turtle Wax. It has solvents and mild abrasives that clean the metal and of course the wax to protect it.
Old 04-28-2004, 05:22 PM
70chevy's Avatar
Eager and Willing to Learn
for small stuff (interior and emblems) We have a bench grinder set up with buffer wheels and fine grit wax sticks. If there is any plastic knobs you have to be careful cause it will melt those pretty quick if those touch but otherwise it works great. I have done lots of stuff and it all looks new. I even took new chrome parts straight out of the box from chevy duty and lmc and put their stuff on the wheels and they came out better!
Old 07-29-2004, 07:44 AM
Location: Justice, Illinois (bred, born and raised in Louisville, Kentucky)
I am a Detailer . We use Green Dragon and then followup with Rod & Custom. Brings back the shine and you can also use the Rod & Custom on your vehicle too.
Old 07-30-2004, 05:50 AM
cboy's Avatar
Last journal entry: Finished
Speaking of chrome I was recently told to stay away from chroming ANYTHING on the car because the chrome shops have had to alter their process and formula so radically due to hazardous materials that chrome is no longer able to hold up to common wear and tear. Any truth to that?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 08-03-2004, 09:51 PM
I've had very good results with Heavy Metal [blue] Makes the Chrome Bumpers on my 91-Slammed, long cab-long bed, stand tall. Also workes GREAT on un-coated aluminum...
Old 08-04-2004, 10:05 AM
I've had lots of pieces chromed over the years. I am sure that over the years, the process and formulas have changed due to materials, compounds and chemicals that are used in the chroming process. However, I do not believe that with the new technology we possess in this world today, that chrome is no longer able to hold up to common wear and tear. I think that is false and a myth. From my experience and with the recent chroming I've had done, my chrome is holding up just fine.
Anyone else with any thoughts on this issue?
Old 08-04-2004, 03:03 PM
Rockey's Avatar
I use good old Windex window cleaner on my chromed out Harley Davidson. Some good old MC guys mentioned that wax and other polishes fill in the tiny poriouses (unseen with the eye)
an after awhile would dull the chrome. Windex works fine for me. It's easy cleaning, spray and wipe dry, no streaking. Give it a try.
Old 08-04-2004, 03:17 PM
So your're a Harley Dude? And, I am a Harley Gal! Love to feel the wind on my face and my hair being blown. Here's a Harley shake for you as we're passing by each other:
I used to use Windex on my Harley, on the windshield and chrome. But found that when I was tooling down the highway, bugs were sticking to my windshield and anywhere else they could splatter themselves. So, I tried Motorcycle Show Gloss Creme on my Harley and now I don't have any bugs or dirt or grime that stick to any part of my Harley. I don't get any streaking either and its great for my paint and chrome!
Old 08-06-2004, 07:17 PM
mitmaks's Avatar
Last journal entry: Grille
Ive used GS-27 scratch remover and it works great on chrome
Old 08-09-2004, 07:27 AM
I have hear the same as Rocky, that car wax isn't a good thing for chrome as it blocks microscopic pores that chrome needs to "breathe". I have used/tried all of the above I think. On my Harley I had to do a lot of work since the previous owner didn't care what it looked like as long as it ran. THe aluminum on the bike was in pretty sad shape. I bought some "Blue Magic" and made the cast stuff shine like chrome, and on chrome it takes a lot of the abuse out except for rust.
Old 08-11-2004, 07:29 PM
Still recommend either the Green Dragon for the chrome or the Rod & Custom Show Gloss Creme.
