Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - crome Painting?
Thread: crome Painting?
Old 01-27-2013, 09:06 AM
nicamarvin nicamarvin is offline
Originally Posted by RLDSL View Post
not to hijack, but Just how good did that Ceracote stuff look close up ( I checked the link but the pics were a bit hard to tell )?
I realize it has to be cured at above 500 deg... but I also happen to own a kiln that will adjust down , large enough to hold the pieces that I want to fool with , and that stuff has an attractive price, not to mention looking like a lot less fuss to apply.
up close it looks like polished steel, its not as shiny as the Innate chrome paint. and it has to be cured above 500. if not it will come out the second you wash it with water. I did the sample on plastic to see if it could hold on lower temps, but it didnt. clear coating it wont work either. this is truly meant for metals, and it needs properly prep if not it will flake off. so its not so easy to pull it off
