crome Painting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2013, 04:10 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
crome Painting?
how does the crome paint work?
Old 01-23-2013, 05:45 AM
I just made a fiberglass fan shroud and painted it with upps-a color chrome paint. It DOES NOT look like chrome. Want it does come of like is aluminum. You can hardly tell the difference in the aluminum radiator and the shroud.
Old 01-23-2013, 05:56 AM
BOBCRMAN@aol.com's Avatar
Alsa Corp | The World's Most Exotic Paints and Finishes
Old 01-23-2013, 10:30 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Several people have tried that stuff and so far have not heard of too many with a good result. Factory chrome these days is done by a process of vacuum depositation which is way beyond the scope of any but the most dedicated hobbyist.
Sam
Old 01-24-2013, 09:40 AM
Sam
Im thinking about getting the Spectra chrome line. http://sprayonchrome.com/
have any body tryed it?
Old 01-25-2013, 06:21 PM
chrome paint is one of the must difficult if not the must dificult paint to get right..
but if you do it right and use the best chrome paints out there like Innate Chrome, you can reproduce a very realistic chrome like surface..
I´ve done a few reviews on chrome like coatings..
here is my latest review on the "Innate Chrome Paint"
THE H.A.M.B. - View Single Post - DIY Spray On Chrome
here is an old one
Alsa Stretch Chrome Film vs Innate Chrome
Cerakote Chromex ceramic coating review(on the shine properties, not heat)
Cerakote Chromex Ceramic coating review - THE H.A.M.B.
But the Only coating like system that can even outshine real chrome is "Spray On chrome" while not entirely a coating system, more like a Hybrid system, between chemical(silver nitrate) and paint(the silver goes in between the glossy basecoat and the protective clear coat). if you thought chrome paint was difficult, then Spray on chrome makes it look like child´s play, But I´ve done a How to, so anybody crazy enough can do it..
here is the thread, make sure to read it all if you want to learn how to do it.
DIY Spray On Chrome - THE H.A.M.B.
some videos
Innate Chrome
Spray On Chrome
Old 01-26-2013, 10:35 PM
here is an old one
some videos
Innate Chrome
Spray On Chrome
not to hijack, but Just how good did that Ceracote stuff look close up ( I checked the link but the pics were a bit hard to tell )?
I realize it has to be cured at above 500 deg... but I also happen to own a kiln that will adjust down , large enough to hold the pieces that I want to fool with , and that stuff has an attractive price, not to mention looking like a lot less fuss to apply.
Old 01-27-2013, 09:06 AM
up close it looks like polished steel, its not as shiny as the Innate chrome paint. and it has to be cured above 500. if not it will come out the second you wash it with water. I did the sample on plastic to see if it could hold on lower temps, but it didnt. clear coating it wont work either. this is truly meant for metals, and it needs properly prep if not it will flake off. so its not so easy to pull it off
painting ranchss@comcast.net Body - Exterior 1 12-29-2011 07:15 AM
crome air comp. bob eaton Engine 1 01-26-2007 11:32 PM
welding crome moly and thin tubing tig welder Introduce Yourself 2 12-17-2006 04:50 PM
Painting Crome Image ceedy Body - Exterior 1 04-19-2006 09:45 AM
crome 78 chevy truck Body - Exterior 14 08-11-2004 07:29 PM
