Crosley-T-400 Bushing too tight? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 01:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Crosley, I'm finishing my T-400 rebuild and have a couple of issues I'd like to run by you.
Using a Hughes master kit I've replaced all bushings. The pump bushing seems too tight, I had to rotate the input shaft back and forth to get it past the inner bushing (smashing my finger when it dropped through...). The pass through the front bushing was easy, but the front hub won't "spin" freely, it can be rotated with one finger but won't spin. Is the clearance to tight, enough to burn up the bushing right off the bat? Is there an easy fix without damaging the new bushing? They were all pressed in square and correctly with a hydraulic press and correct size installation tool.
The rebuild kit came with several bi-metal spacer bushings where the original parts were nylon, specifically the planetary (4 tang) and center support spacers and the pump washer between the pump and forward clutch hub. Given they are the correct thickness for end play, am I OK using the metal replacements vs. the old nylon ones? Is there any place I should not use the metal replacements?
Again, thanks for the help!
Old 09-02-2005, 07:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I do not use plastic thrust washers when possible.
Tight bushings on the stator support where the input shaft passes thru is a common deal. I am not sure why.
I have chucked the stator in a lathe and polished the bushings with 100 grit paper... or use a dingle ball hone to open the bushings up or use a plastic dead blow hammer against the input shaft to "set" the bushings a bit to see if they loosen up.
Sometimes an edge forms when the bushings are pressed in
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 09:08 PM
Need advice on building 400 chevy roddinron Engine 1 01-24-2005 03:16 PM
very tight new bbc- HELP bailey40ford Engine 9 03-07-2004 09:25 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 04:41 PM
400 327 crank limey Engine 8 09-24-2002 08:53 AM
