Hello-
I just ordered a new steel Scat crank for my low boost 6-71 454 project. I couldn't really afford the forged one so I went for a cast steel. This engine will see 5-8 lbs of boost and will
only be a street driven, weekend cruiser.
I couldn't decide between the Eagle and the Scat. I went with the Scat and ordered it from Summit. Only
after I ordered it did I realize that it had cross drilled mains, I just overlooked it
Is this going to be a problem? Do I need different style bearings. I have done some research here, but it didn't really answer my question. I do have a high volume oil pump. I plan on sending it out for the double keyway.
http://www.summitracing.com/parts/SCA-910454/
**EDIT**
I went to the Scat websight and found this. WTH?
They say they WILL NOT cross drill.
"SCAT is committed to manufacturing only the highest quality
crankshafts and we WILL NOT cross drill cranks even though the
process is easier and cheaper."
http://www.scatcrankshafts.com/scatt...s_Drilling.pdf
Do you think this is a misprint on the Summit site? Guess I will give them a call.
Thank you for looking
Steve
