Cross drilled mains? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2010, 08:31 PM
NOlowrider's Avatar
US Navy-Retired
Hello-
I just ordered a new steel Scat crank for my low boost 6-71 454 project. I couldn't really afford the forged one so I went for a cast steel. This engine will see 5-8 lbs of boost and will only be a street driven, weekend cruiser.
I couldn't decide between the Eagle and the Scat. I went with the Scat and ordered it from Summit. Only after I ordered it did I realize that it had cross drilled mains, I just overlooked it Is this going to be a problem? Do I need different style bearings. I have done some research here, but it didn't really answer my question. I do have a high volume oil pump. I plan on sending it out for the double keyway.
http://www.summitracing.com/parts/SCA-910454/
**EDIT**
I went to the Scat websight and found this. WTH?
They say they WILL NOT cross drill.
"SCAT is committed to manufacturing only the highest quality
crankshafts and we WILL NOT cross drill cranks even though the
process is easier and cheaper."
http://www.scatcrankshafts.com/scatt...s_Drilling.pdf
Do you think this is a misprint on the Summit site? Guess I will give them a call.
Thank you for looking
Steve
Old 04-21-2010, 08:55 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Steve,
The cross drill is for continues oiling, the bearings one half has a grove in it,
& as one hole is covered by the solid half of the bearing, the other hole opens.
Rich
Old 04-22-2010, 06:34 AM
NOlowrider's Avatar
US Navy-Retired
anyone else?
Thank you, Rich for your reply.
Old 04-22-2010, 07:09 AM
Last journal entry: Bringing home the 401 Nailhead
Originally Posted by NOlowrider
**EDIT**
Steve
Could very well be a misprint on Summit. Summit support has always been good IMO but I would call Scat and confirm.
Old 04-22-2010, 08:03 AM
35WINDOW's Avatar
Last journal entry: Engine!
Read this Article-
http://www.rehermorrison.com/blog/?p=214
Old 04-22-2010, 12:26 PM
NOlowrider's Avatar
US Navy-Retired
Just talked to Scat and they said that the crank is NOT cross drilled. It is incorrectly identified on the Summit site. Good news for me. I was not really thrilled about it being cross drilled.
Thanks to all the replied.
Tranny to cross member alignment issue Blue67Camaro Transmission - Rearend 5 01-14-2008 01:24 PM
Cross drilled mains? kringold Hotrodding Basics 7 07-08-2007 06:47 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
Cross Drilled Crank 35WINDOW Engine 3 02-14-2006 02:21 PM
Ford granada cross drilled rotors FAIRLANE DUDE Suspension - Brakes - Steering 3 03-08-2003 03:59 PM
