cross/fire, dimensions problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 06:45 PM
I painted a car on saturday with crossfire/basecoat clearcoat gm fleet white and it looked good ,but after a couple hours it looks like really tiny bumps or solvent popping. It was around 75 degres, i used a fast/med reducer and ch5ooo clear.I painted 3 coats of base with a 10 min flash time and 30 min before clear. I painted a truck door in july with tech base and it did fine, but everytime i use dimensions or cross/fire i get the same problem?I used a gti millineum gun with all of them. I have a friend who paints air planes and he painted a can with the sherwin williams paint they use and after a month i sanded it with a scotchbrite and cleared it with ch5000 when i painted the car and it turned out fine. So i know it isn't all me, I think it is the paint.I think the reducer or hardner is causing the problem. The cross/fire uses the same reducer in the base and clear.It might be me the problem but i have painted 5 other vehicles with dimensions and haven't had this problem until about a year ago. I'm about ready to give up but i would really like to know if it is me or paint the problem!
Old 11-13-2006, 08:15 PM
adtkart@aol.com
If you got solvent pop, you probably should have waited longer to spray the clear. Shooting clear after 30 minutes, over 3 coats of base, at 75 degrees, seems too rushed to me.
Aaron
Old 11-14-2006, 04:52 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
arons right. you got back on it too soon. just polish it out.
Old 11-14-2006, 07:18 PM
crossfire buffing
Since shine said polish it out i decided to try water sanding and buffing it. I sanded it with 2000 grit and buffed with a foam pad and meguires fine cut cleaner and it turned out great. Being that it's a omar jets car i'm pretty shure their gonna beat it up in parade's anyway. Thank's for all ya'lls help. I don't know if ya'll realize how helpful ya'll are but i really appreciate the help.
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 05:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
