Cross Flow Exhaust.............. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2003, 06:47 PM
bg's Avatar
bg bg is offline
Post Cross Flow Exhaust..............
How important is a cross flow on an exhaust system???
I have a set of sanderson headers and a set of flowmasters 50 series and was wondering if i should put a cross over flow tube in the dual 2.50inch exhaust tubes.
Also how far back should you go before you put in a cross over. I would think the sooner the better!
thanks
Bg
<img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" /> <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 04-11-2003, 10:22 PM
Post
I just installed an X pipe on my system....It really helps to balance the exhaust system. And I noticed better performance after I installed the x pipe........ I would recomend a X pipe over a H pipe..... My X pipe starts right after the headers......
Old 04-12-2003, 02:47 AM
slider in wa's Avatar
Slider in Wa.
Post
Trick, where did you buy the "X" pipe and how much did it cost? Thanks.
Slider in Wa.
Old 04-12-2003, 04:13 AM
New Member
Post
I don't know about the X pipe,but the cross tube or h pipe gives more torque and I have always heard to put it in the system in the best place you take a paint stick or paint can and paint a line on both pipes and drive the car a short while and look under the car and the point where the paint burns off first is where you want to put your H pipe for the most good.
Old 04-12-2003, 05:13 PM
Post
Slider I purchased a X pipe get from Summit. Cost was $120.00. Headman Headers makes it. You can also purchase just the X and have the other pipes bent. Just the X is $80.00 I had to use the universal kit for my car. It took a little fabrication but I was able to make it fit great. They have a lot of kits made for specific cars....
[ April 12, 2003: Message edited by: trick66 ]
[ April 12, 2003: Message edited by: trick66 ]</p>
Old 04-12-2003, 06:16 PM
5.0Towncar's Avatar
Post
I hated my H-pipe!!!!!!!!!!!!!!!!! Steve
Old 01-21-2004, 07:09 PM
r8ptan8's Avatar
what is the sound difference between the two? Which sounds the best?
