Cross member actual strength?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2005, 11:40 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
We need to modify or replace the stock cross member on the 78 Malibu.
We are running a 3" exaust off the 496 BB headers and with the collector on the driver side being a few inch's from it as well as the pipe not clearing are trying to deside what to do. The replacement double hump one won't clear the big pipe either as we looked at that.
My question is, How much actual load/torque is this piece under?
We run mufflers in our class so just open headers is not an option.
We are considering "C" notching and reinforcing with boxing the open end's,flat stock on top, and a "U" (bottom piece of a loop)on the underside.
This total overkill?
Any other options?
Thanks, Mike.
Old 08-26-2005, 07:33 PM
New Member
Big pipe Blues
That has a fair load but not as much as you're motor mounts.
It does however serve as a frame stiffener too.
This might sound strange, but is there room to slightly flatten out
your pipe into an oval, retaining the original area inside?
I had to do this on a 'Cuda and it worked well.
KYWT
D
Old 08-27-2005, 06:50 AM
Garbonzo Bojangles's Avatar
Youre confusion is not logical
[QUOTE=Bee4Me]...flat stock on top, and a "U" (bottom piece of a loop)on the underside.[QUOTE]
That's what I did to the crossmember in the driver's side in my 442. My engine makes 500 ft-lbs and it's held up fine so far. If this Malibu is a drag car you might want to look into a roll cage to stiffen the entire chassis, though.
Old 09-02-2005, 07:42 PM
acr acr is offline
Take a look at the oval exhaust pipe & the Frame Clearance Tubes Dr. Gas sells. www.drgas.com
Old 09-02-2005, 09:13 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
This what I did. I took the stock cross member and welded a piece of channel to the top. Then i cut the entire section of crossmemeber out.
9" ford 3rd member strength? 68c10owner Transmission - Rearend 10 06-13-2007 09:45 AM
57 Chevy auto trans cross member pikalpha Transmission - Rearend 7 12-09-2005 01:02 PM
Meaning of the iron cross? FASTCHEVY Hotrodders' Lounge 15 03-05-2004 11:01 PM
mustang 11 cross member 38harry Suspension - Brakes - Steering 0 01-28-2004 12:47 PM
84 C10 TH350 Cross member to a 700r4 mount??????? juveteach Transmission - Rearend 3 06-13-2003 10:54 AM
