Cross spring over straight axle crossmember
Trying to help a guy with this axle - spring setup for a proper cross member to mount it.
Been looking at Speedway Motors cross members for model A and 32 Ford. Also looking the U bolt mount kits for the cross member Chassis will probably be a 2x3 inch square tube type. Will need some hairpins, clevis parts from axle to frame too Are we headed in the proper direction here?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Got a question? Is it to be a suicide front or conventional like henry made it? One comment is that I would go with 2x4 for a bit stiffer chassis..Early fords were 6 inch in the belly of the chassis and tapered front and rear..
Crossmember can be as simple as making a plate drilled in the center for the spring bolt and 4 bolts for the clamping of the spring and then weld that to a piece of tube for the crossmember..make another plate with the same bolt pattern to clamp the spring..You can make the hairpins and batwings as well.. Sam
as you look at the photo.. the spring is on top of the axle. Not gonna be a suicide type suspension with spring behind axle line.
I've received some ideas for building a cross member from tube
| Straight Axle mix | palmer6691 | Suspension - Brakes - Steering | 5 | 01-25-2010 08:37 PM |
| front straight axle on 32 ford model b truck | BonnevilleBrat | Suspension - Brakes - Steering | 6 | 01-28-2009 11:00 PM |
| transverse spring & straight axle | 26trackt | Suspension - Brakes - Steering | 3 | 01-18-2003 11:45 PM |
| straight axle falcon | kalowry | Suspension - Brakes - Steering | 13 | 01-04-2003 03:26 PM |
| 1938 chev - straight axle front end | WILLARD(SONNY)STOTLER | Suspension - Brakes - Steering | 4 | 12-30-2001 03:26 PM |
