Have you mocked up the motor yet? ( I guess if you haven't built the frame yet you have not..hahaha) can you lengthen the frame to accomodate the crossteering? You didn't say if you are running fenders, hood etc, which might limit your wheelbase.
If you have clearance for cross steer, that would be my choice. I would NOT recommend any Vega style box for that build, it will self destruct in a short time unless steps are taken to increase it's mechanical advantage. (IMO, there is too much weight on the front wheels for a vega box and have seen them wear out very quickly .) Use a 525 box from a Camaro or similar mid sized GM for cross steer. The guys with more experience with side steering options can tell you about those. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 03-14-2009 at 09:04 AM. Reason: missed something in the OP |
My last project (a fenderless channeled Model 'A' coupe) used the currently popular Vega cross steer. I liked it and would recommend it over the earlier '56 Ford F100 box. The Vega was much easier to steer; even when a smaller diameter steering wheel is used. There also is a rack & pinion box called Uni-Steer that is a bolt on replacement for the Vega box. Speedway Motors offers it as well as other aftermarket suppliers. I have no experience with it. A front panhard bar is recommended when using the cross steer to help eliminate any 'bump' steer. A rigid shackle mount on one side could be utilized instead of the panhard bar and is available at some aftermarket suppliers. |
Thanks Mikey and Frisco
| 50 Ford Tudor Pwr Steering Conersion | Schenkeinstein | Suspension - Brakes - Steering | 5 | 01-29-2010 04:58 PM |
| I have a Model A Pickup to build, have Lots of questions. | 88lowrider | General Rodding Tech | 103 | 05-14-2009 09:46 AM |
| 28 Ford Tudor Sedan roof filler | Marc Connelly | Body - Exterior | 13 | 11-27-2003 06:19 AM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
| 28 ford tudor drip rails | Marc Connelly | Body - Exterior | 1 | 03-01-2002 06:28 PM |
