crossmember & independent suspinsion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2012, 10:25 PM
Can you use 1990's Lincoln or Mercury , crossmember and independent suspinsion on 1964 F-100 1/2 ton pick-up ? The Lincoln crossmember looks like one piece bolt on .I've seen it done on T.V., on Fast & Loud also on Trucks.
Old 07-24-2012, 08:57 AM
RWENUTS's Avatar
Lots of info here.
Ford Truck Enthusiasts Forums - Search Results
independent rear suspension truckboy Suspension - Brakes - Steering 6 05-25-2006 11:33 AM
independent front suspension jayjones Suspension - Brakes - Steering 2 04-20-2004 08:46 PM
help with crossmember on th300&th400 72 Z28 Transmission - Rearend 14 11-14-2003 05:36 PM
independent front suspensions wheel-7 Suspension - Brakes - Steering 2 09-09-2003 12:29 PM
Independent Great '48 Bow Tie Suspension - Brakes - Steering 1 06-02-2002 04:07 PM
