Is an crossover pipe on dual exhaust really worth it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2006, 10:04 PM
Just had duals put on my 66 Galaxie 352 4brl. No crossover pipe was put in. How important is a crossover pipe? Does it improve performance?
WHat is the best method to determine where the pipe should go? I have heard of guys painting a white stripe from the headers back on the underside of the pipe. Drive it until it burns off then look to see where the paint stopped burning. This is the spot to put the H pipe. Anyone ever tried this or is it an old wives tale?
Old 01-06-2006, 05:29 AM
astroracer's Avatar
Do a search on x-pipe or h-pipe... This has been discussed in length here.
This is a link to a site that has some good info you can use...
http://www.boyleworks.com/ta400/psp/exhaust.html
Pages 2 & 3 get into the X-Pipe stuff but the whole article is worth reading.
Mark
Old 01-10-2006, 09:50 PM
Max Keith's Avatar
H or X or balance tubes
Yes, they are worth it, good for bottom and midrange power, and wont hurt top end at all.
Old 01-11-2006, 01:13 AM
They also reduce noise - a quiet car is a fast car because it draws less attention when you put spur to it.
Old 01-13-2006, 12:36 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Just put the crossover where it fits the best. That old locating method was thoroughly tested a couple years ago by one magazine and found to be irrelavent, since every rpm and throttle setting moves the melting/burning point around.
Thanks, that is a good link listed above.
Old 01-13-2006, 03:20 PM
juiced66malibu's Avatar
My Chevelle has a Gear Vendor unit mated to my Turbo 350, so the area for a X or H pipe is very limited. How far back can I go before it is too far? I also have turn downs at my rear axle. My 3" exhaust is all the way back to my turndowns. I guess a good pipe person can fabricate an x or h pipe.
Old 01-13-2006, 07:47 PM
56 Project's Avatar
Last journal entry: I've Changed My Project
If I remember correctly most of the Ford H pipes crossed near the rear of the transmission. Those were on the original duals through the manifolds with no headers.
exhaust crossover crshrmn3 Engine 13 09-23-2008 02:35 PM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
Oil in exhaust crossover??? skeeveman Engine 4 02-10-2005 08:00 PM
Exhaust pipe exit - which is best?? HotRodMan Engine 1 09-18-2002 07:58 PM
Crossover pipe in exhaust Strick Engine 2 09-16-2002 09:33 AM
