crown corveight - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-19-2010, 11:53 AM
crown corveight
Hello, My name is Gordon and I've been a rodder since 1962 when I helped my brother build a hemi powered 34 ford pkp. Then we shoehorned a 283 into a 54 healy aluminum bodied roadster.
In 1972 I built my first corveight, using a 66 2 door with the Saginaw trans.
The Crown kit does not flip the transaxle but runs power through a custom input shaft into the front of the trans and the bell housing is adapted using crowns adapter onto the front of the trans.
I still own the 2nd corveight I built in mid eighties. Same adapter setup. This car has a 350 4 bolt block with a large journal 327 crank, 600 lift roller cam with rev kit and stud girdles, old ported fuely heads, domed pistons and runs nicely up to 7800 rpm. My 2 sons and I have all autocrossed this car, always with great fun. There is something addictive about listening to a smallblock screaming at 8 grand 20 inches from your ears.
sorry for going on and on.
Old 07-19-2010, 02:44 PM
poncho62's Avatar
Wiki Edits: 5
Welcome...Ever use the Kelmark kit?
Old 07-19-2010, 04:11 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
1987 Ford Crown vic "resto-Mod"/04 frame swap interceptor999 Hotrodding Basics 3 03-02-2011 06:34 AM
05 crown vic misfire curtis73 Engine 8 09-21-2010 08:20 PM
Engine Swap for Crown Vic edge Engine 12 11-03-2009 09:38 PM
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
94 Ford Crown Vic DoubleVision Engine 5 05-04-2005 08:35 PM
