Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Crown Vic swap
Thread: Crown Vic swap
Old 07-27-2012, 03:57 PM
Valkyrie5.7's Avatar
Valkyrie5.7 Valkyrie5.7 is offline
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
You're going to want everything from the plenum up off the mustang, including the throttle body. The crown vics air intake will be oriented in the opposite direction, and plenum will be backwards. Other than that, they'll be identical, with exception to possibly the exhaust manifolds. Check to see if the crown vic has had it's intake manifold changed for the revised one with the aluminum crossover. If not, you're going to have to replace that likely soon.
