cruise control ford super duty - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2008, 10:56 AM
I have a 97 motorhome on ford super duty chassis. My cruise does not work the light does not come on nothing? It only has 16,000 miles on this thing its hardly been used kind of surprised the cruise don't work. Where do i start looking for the problem havent ever dealt with any cruise control isues. Thanks to anyone that may have some experience with these.
Old 01-23-2008, 12:54 PM
cboy's Avatar
Last journal entry: Finished
Just for starters...did it once work and then quite working or has it never worked (at least during your ownership)?
Also, do you have a wiring diagram?
Always learning...and sharing what I've learned.
Old 01-23-2008, 01:43 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Let me ask you this, did you already take it in to a Ford dealership for the recall? If you did, they might not have completed it, as most ran out of the parts long ago. They will just disconnect the brake shut off switch at the master cylinder. I would look there.
Another possibility is the switch itself (at the master cylinder) is leaking, causing a short. I would look there first.
Jason
Old 01-23-2008, 02:03 PM
Ok i think it is a re-call issue. I had to import this vehicle from the u.s. to canada when i went to get the re-call letter they stated there was a recall on the cruise but they cant pull up any info on it so they figured its completed. The guy i bought it from said exactly that it had a re-call and the dealerships there dident have the parts. They must have dis-connected it then. The ford dealership where i am said there not sure on a motorhome where they would have dis-connected it. Being a class c i imagine it would be the same as any truck. I'll look at the master cylynder as soon as it warms up here were in -30 wheather right now. It seems frod does not have a real clear record of re-calls history like g.m. does. They said they cant get any info on the re-call because its from the u.s.?
Old 01-23-2008, 02:23 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Post your VIN and I will run it in the Ford system.
Jason
Old 01-23-2008, 02:35 PM
1FDLE40S9VHB05955
I looked at the master it looks like everything is connected just see 1 wire going to it? Its a little difficult to see in there a lot of stuff around it is there another wire there i should be looking for? Thanks for running the v.i.n. for me.
Old 01-23-2008, 02:41 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
O.K. the recall is still open on it.
On the master cylinder, usually (motorhomes are exception at times) there is a round (about 1" across) switch that comes out of the top, front or passenger side low (depending on model). It will have a rectangular connector plugged into it. When they disconnect it, they just usually leave it off to the side hanging. The switch will always remain in the master cylinder. I have seen some of the motorhomes difficult to find. Keep looking it will be there.
Jason
Old 01-23-2008, 02:43 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
OASIS RESULT:
1FDLE40S9VHB05955
01/23/2008
15:37:04
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
Errors
VIN OUTSIDE OF SUPPORTED 10 MODEL YEAR RANGE
ALL APPLICABLE FIELD SERVICE ACTIONS WILL DISPLAY
ARN MESSAGES
OUTSTANDING FIELD SERVICE ACTIONS
05S28
RECALL 05S28 S#14 WILL BE ISSUED WK OF 1/28 TO AUTHORIZE REPAIRS ON CAR VEHICLE APPLICATIONS. THE NEW SERVICE PART WILL BE SEED STOCKED WK OF 1/28.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
| On-line 1878
END OF OASIS REPORT FOR 1FDLE40S9VHB05955
Here is what was on the report. Vehicle to old to pull any history or build information.
Jason
Old 01-23-2008, 02:48 PM
Thanks jason. Are you saying this may be dis-connected on the passenger side of the master cylinder or am i looking for another connection comming out around the passenger side of the vehicle? Thanks
Old 01-23-2008, 02:51 PM
Just googled tha re-call # it does come up as a cruise control re-call and by the looks of what it says there they were out of stock on the parts. I guess i'll keep searching for the place they dis-connected it.
Old 01-23-2008, 05:13 PM
41willys's Avatar
Blowin' it
Wiki Edits: 11
Yes, it "could" be disconnected. I am just saying that would be the first thing I would look at. As far as the exact location, it varies with the motorhomes. We have seen them all done differently, sometimes the M/C is changed, but still has the original set up for the disconnect switch. You may have to search around the M/C area to locate it, due to sometimes a mess of wires and other components they install there.
Jason
Old 02-01-2008, 04:20 PM
well i searched pretty good today to see if i could find anything dis-connected but i really cant find anything. The cruise does not seem to do anything when i hit the switch where would i start now? Is it hard to get to the switch its on the steering wheel i have never done one of these fords. I guess if i get to the switch i could check to see if power is getting there? In a seperate matter i need to install daytime running lights in this motorhome also since i'm in canada and its from the states i'm required to put them in. I can get the module from a parts store here for about 25 bucks. I noticed there is a fuse that has daytime running lights listed on it and also theres another place where there is a module for daytime running lights according to the owners manual i believe somewhere under the hood. Is it possible i may just be able to plug the module in? Or am i just dreaming it would be that easy? thanks sorry for the long post got a little carried away.
Cruise Control Mr. Jigs Electrical 3 01-13-2006 08:59 AM
Cruise Control Wiring Assignments jpd37 Electrical 1 09-30-2003 05:23 PM
Lincoln Mark 7 cruise control NAIRB Electrical 2 05-19-2003 05:02 PM
Ford's Super Heavy Duty Transmission Capacity sum87mustang Transmission - Rearend 1 04-12-2003 04:33 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
