cruise control problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2004, 09:39 PM
stfinney's Avatar
Whenever my cruise control is on and I have to turn my lights on, for rain or night-time, my cruise turns off. This is because when my lights turn on, the 3rd brake light comes on and stays on. Could it be a sensor or something causing that? Any help would be appreciated!! TIA!
Old 08-16-2004, 08:19 AM
cboy's Avatar
Last journal entry: Finished
Is this a "stock" wiring set up or did someone wire in the third brake light after the fact? It sounds to me like the 3rd light got wired to the running lights circuit (on when headlights are on) rather than the to the circuit which comes from the brake switch (on only when brakes are applied). I don't think the 3rd light should come on at all when you turn your headlights on.
Always learning...and sharing what I've learned.
Old 08-16-2004, 08:49 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Check the bulb, could be shorted or wrong. Or like posted, wired wrong.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 08-16-2004, 05:03 PM
docvette's Avatar
Wiki Edits: 12
Third Brake light
[color=yellow]Doc Here
Is the 3 Rd brake light a duel filament bulb type?
Unless it is, your problem is going to be there if you have tail and brake lights at that lamp.
The Brake and tail lights can not be on the same circuit or all will come on and stay on when the lights are turned on, making the Cruise control think your riding the brake.
Doc
[/color]
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-16-2004, 09:27 PM
stfinney's Avatar
It's on a 1994 car, so it is stock. It didn't used to do that. It worked fine. I'll check the bulb and see. I didn't think of that. Could the brake switch be bad? It should be a single filament bulb, as it should only come one when the brake is applied.
Old 08-16-2004, 09:33 PM
troy-curt's Avatar
If the switch was bad, all the brake lights would be on.
It should be single filament bulb.
Try unhooking it or removing the bulb, and then go from there.
Troy
Old 08-20-2004, 09:31 PM
stfinney's Avatar
Ok, I took out the bulbs, yes bulbs, 2 of them. They are the little push in bulbs. Anyway, I took them out and it still does the same thing, so I'm assuming that there is something else wrong. Any ideas? Could another bulb from the actual tail-lights be causing it?
Old 08-20-2004, 10:05 PM
New Member
It souds like the third brake light is wired wrong and feing back through the brake switch. I would try to totally unhook the third brake light and see if it clears up the cruise problem
Old 08-20-2004, 11:24 PM
docvette's Avatar
Wiki Edits: 12
quick thought...
[color=yellow]Doc
Just a real quick thought, did you recently have a trailer hitch installed, or tow a trailer? Miswires and shorts are common at the hitch plug...
other than that, you need to locate the 3 Rd light wires, With a DMM , find which wires are hot when the headlights/park lights are on, and which wires are hot only with brake lights.
Though I do not believe the 3Rd light should be on when the lights are on, with 2 bulbs , although It would seem that it was intended to be that way.
Make sure that one bulb has Brake light power and ground on it only.
The other will be Tail light power and ground only and will be the dimmer of the 2 bulbs.
Do not tie both power wires together...
BTW, if it's working that way now, All your brake lights Should on anytime you turn the headlights on too...not a good thing with a tailgater...
Also if the grounds were tied together before going to a ground wire, and you lost one ground it would backfeed through the other bulb looking for a ground, so use two separate hard grounds..
Doc
[/color]
Innovations
