cruise controll doesnt work for crap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2010, 09:15 PM
chevy1500z71's Avatar
first of all thsi is for a 95 chevy haft ton pickup.my cruise control has always worked very well even with the supercharger and everyhting but after i swapped my automatic trans for a manual its just not the same, infact it kind of scary.
heres what it does, i just got on the highway, im in 5th gear and its the first time i go to use the cruise control. seems to work great, untill i go uphill and realize that it is holding my throttle position but not compensating for the hill, i loose 5mph going up the hill and it does nothing about it. ok, no big deal, it may not work 100% but at least it holds the throttle so i dont have to. then i tap the brake pedal and it doesnt disengage, in a panic i manually turn it off and it goes off. i reach to use it again and depending on its mood it may or may not work again, if it does work it may not let me use the speed up feature which normally works. normally it simply will not work after the first few times i turn it off. if it decides not to work, its not a blown fuse becasue the next day its back in business again and ready to do the same thing all over, work for a little while and then stop working.
i dont know what it is, does the cruise control module need input from the trans for tcc lockup and things like that? all the functions associated with an automatic trans have been removed from my ecm in its tune... i assume it gets its information from the ecm so i dont know why its still acting funny after i completely retuned the ecm, i went through everything and made sure everything associated with the automatic trans is gone from the tune.
Old 02-11-2010, 08:03 AM
Wiki Edits: 31
IIRC the trans has a speed sensor the cruise uses
T-bucket23's Avatar
Wiki Edits: 26
I would check to be sure your didnt damage the harness when you changed over the transmission. Maybe you pinched some wires or left a ground off somewhere.
Chet
Old 02-11-2010, 02:13 PM
i was definitely sure to get all the grounds hooked up, iv been down that road before, if i missed a ground, i would know it. however, if there was a ground in one of the connectors that was exclusive to the cruise control it could be an issue, becasue i have 3 or 4 connectors that went into the auto trans that are just not pluged into anything, thats no big deal since the ecm no longer cares about those wires, i could remove them all together, i was juts lazy and left them... unless there's something for the cruise control in there?
the vehicle speed sensor is in the transfer case tail housing since its a 4x4 truck, so that wasnt harmed during the trans swap.
everything on the truck works, the cruise control is the only thing giving me trouble...
How much Work do you do? budthespud General Rodding Tech 31 01-03-2008 09:08 AM
Well, I wont be here much until harvest ends or why you should not work for relatives CrashFarmer2 Off-Topic 9 11-11-2007 07:15 AM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
89 honda accord, headlights wont work...and... Rubberman2003 Electrical 6 02-10-2005 05:26 AM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 04:57 PM
