crush sleeve - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2003, 05:57 PM
Post crush sleeve
what does a pinion crush sleeve do?
Old 04-17-2003, 06:03 PM
4 Jaw Chuck's Avatar
Post
Maintains preload on the pinion bearing which allows for some wear to occur during it's lifetime so that there is no need to periodically adjust it.
— Han Solo
Old 04-17-2003, 07:09 PM
BOBCRMAN@aol.com's Avatar
Post
yes the crush sleeve keeps preload on inner race to keep it from spinning, in my old draggin days we used to re-use them and locktite the bearing, works well if you are changing gears often.
Old 04-18-2003, 03:34 AM
woodz428's Avatar
Troll Hunter
Arrow
It used to be that you set up the pinion bearings with a solid sleeve and spacers, it was time consuming and too hard for inexperienced line mechanics to do correctly. They introduced crush sleeves to simplify the job by having a spacer that "crushed" a specified amount under torquing.
