crush sleeve question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2009, 03:43 PM
72 grabber 51F-1 65 chevystang
I am setting up an 8 inch ford rearend that came out of a 73 maverick and I can not find a crush sleeve for an 8 inch. I can only find one for an 8.8 inch. I was wondering if they are interchangeable, if not where can I get one. I have tried the auto parts stores summit and jegs with no luck. All I have found is the total rebuild kits that are over $100. Any help is appreciated
Old 01-13-2009, 03:49 PM
prostreet6t9's Avatar
Differential/Driveline
Ratech part# 3101
Old 01-13-2009, 04:15 PM
thanks. I ordered the $31 rebuild kit
Old 01-14-2009, 08:37 AM
I recommend using the solid sleeve kit from Currie.
That is a much better situation than a crush sleeve.
I also recommend only Timken bearings on a rebuild.
Old 01-14-2009, 10:32 AM
Ratech makes a solid one also.Part #4114. A solid spacer is a better set up,But there is nothing wrong with a proberly set up crush sleeve.
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
crush sleeve / solid pinion spacer olds79 Transmission - Rearend 4 10-01-2006 09:40 AM
8 1/4 pinion crush collar wildfire78 Transmission - Rearend 2 08-07-2005 10:16 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
crush sleeve layinitdown Transmission - Rearend 3 04-18-2003 03:34 AM
