I've built hundreds of rear ends myself and I've never had a bearing problem caused by a crush spacer. I haven't seen any benefits in using a solid spacer. I had a few Ratech crush spacers split in the seam when crushing them, but that was just a few for the Chevy car 12 bolt. I haven't seen that problem again in years.
I have no idea if this is relative to a crush sleeve or spacer discussion but since you guys have had a lot of experience building diffs, maybe this makes some kind of sense to you as I have thought my problem was related to crush sleeve movement:
I had a 3.40 ratio truck 12 bolt in my Chevy ½ ton. It was a junkyard replacement for the 2.76 I used to have, but put it in and no noise whatsoever. Worked fine except for the Gov-lok that didn’t work. I took it to a very well known, diff-specialization shop to have a rebuilt Eaton Positrac installed. They had to torch out the old, non-working Gov-lok in order to install the Eaton. That is where I think the problems might have started. They reinstalled the old 3.40 gears again and the new Eaton along with new bearings at their suggestion. Well, 5 days later I started to get gear noise but only after doing WOT runs. My trucks shifts rather hard on the 1-2 change. It has a 325-350 HP 350 and a TH350 with a shift kit. Anyway, doing 5 more WOT 1-2 shifts toasted the rear gears. Lots of growl and ugly noises. Took it back to the shop. They said well sometimes reinstalling R&P can destroy them as the original wear pattern doesn’t match exactly the same when reinstalled. Fair enough. They covered install, I covered parts for new Yukon 3.73 gears. Followed break-in procedure to the T, then at the first WOT run with a 1-2 shift I got a little noise. Another shift, more noise. 3 more WOT 1-2 shifts and I’m back to square one: toasted R&P. I’m mad, they are mad and blame it on my ‘race’ truck. Long story short, they replaced the 3.73 Yukons with the same. Break-in procedure again followed to a T. First WOT 1-2 shift and here comes the noise. I do 2 more of those and I know where things are headed. I phone them back, we are all mad again and they have no explanation for me. I ask if the crush sleeve is moving on the 1-2 shift, causing the bearing preload to be lost, letting the ring touch the pinion. They just maybe. I said maybe it was when you torched out my old Gov-lok that you tweaked my housing. They said maybe, but find us another housing at your cost and we’ll replace everything again. I said do you know for sure if I’ll have the same problem? They said nope. After a BBB complaint I said I want my money back, every dime I spent. They said okay, just give us back the Posi. I said fine, gutted my diff and gave it back. So, after all that, any idea on what it was? I ended up finding another 3.40 Gov-lok and put it in. The previous housing is sitting in my garage. At least I have a spare set of axles! |
My guess would be that the bearing preload wasn't set correctly when the rear end was assembled. I've built many 12 bolt, 8.2 and 8.5 10 bolts and 8.8 Fords that were abused much more than that with no problems. They all had crush spacers in them. I built a 8.2 10 bolt that went into a '69 Camaro with a 383 and 4 speed that was lifting the front tires with slicks and it didn't give any trouble. It also had a crush spacer in it.
A lot can be told when disassembling the differential. Where the pinion Brgs burnt up? Are the Pinion Brg races tight in the housing? If either of the races are spinning in the housing the Brgs will fail prematurely even with the correct preload. |
Long time ago when I attended Ford Motor Co school on rear axles the one thing they continually drove home is do not use an air impact wrench to crush the sleeve and pre-load the pinion bearings. I have seen this done more times than not, even on some highly touted hot rod TV shows. Yes I have seen rear axles go 100K+ that had the sleeve crushed with an impact.
Think about what is happening to those new bearings as that impact is hammering away. I prefer not to take the chance and use a breaker bar with cheater pipe to establish pinion preload. Vince |
I do think the solid spacer is a little easier for the little less experienced guy to use.
The stock car guys all want to minimize friction meaning they run with almost no preload, on a unit that has been dynoed or pre-run. The preload is set to a minimum,ie zero, and the unit will run that way. |
| crush sleeve question | old fords | Transmission - Rearend | 4 | 01-14-2009 10:32 AM |
| Crush sleeve... can someone 'splain it to me? | curtis73 | Transmission - Rearend | 9 | 12-03-2008 01:53 PM |
| Ten-Bolt Rebuild - Without Crush Sleeve? | nova69 | Transmission - Rearend | 2 | 01-23-2007 05:35 PM |
| crush sleeve / solid pinion spacer | olds79 | Transmission - Rearend | 4 | 10-01-2006 09:40 AM |
| crush sleeve | layinitdown | Transmission - Rearend | 3 | 04-18-2003 03:34 AM |
