Cs130? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 12:09 PM
47 Coupe's Avatar
Cs130?
I'm trying to find out about the if you connect the "F" terminal without an idiot light or the "L" terminal with a light or resistor.
In other words can I hook a switched 12v without any resistor to the "F" terminal and have it work.
Thanks
Old 10-23-2012, 06:48 AM
yes you can use the F terminal without a resistor. The F terminal was used on cars with voltmeters. However, there are some alternators that have no internal connection to the F terminal and will not work. Give it a try and if it doesn't work, the regulator can be changed to one that will.
Old 10-23-2012, 07:03 AM
47 Coupe's Avatar
The plug that came on the alternator had a small wire on "F" and a small wire on "L". Nothing on "S" or "P"
Old 10-23-2012, 08:30 AM
If it already has an F wire then you can just connect switched power to it and leave the L wire disconnected. The S wire is a sense wire and is not often used unless the vehicle has dual batteries and the aux. battery is being monitored. The P wire is for phase or pulse depending on who you talk to. It is used to provide a tachometer signal for Diesels and some computer controlled functions.
Old 10-23-2012, 12:13 PM
47 Coupe's Avatar
Works great, holds 14v at idle. Thanks for your help
CS130 alternator 6426yy Electrical 5 02-24-2011 11:21 AM
CS130 Wiring Question Blaster Electrical 4 07-04-2007 04:48 PM
CS130 Wiring Blaster Electrical 3 05-03-2007 12:26 AM
1 more cs130 wiring question 84cutlass Electrical 6 07-14-2006 05:48 AM
CS130 alternator 'size' cucumber1949 Electrical 6 12-25-2005 09:17 AM
