Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cs130 Alternator
Old 01-13-2013, 04:52 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
It's basicly like the one you had, if you had converted to a internal regulator. If you haven't converted, it's a little more complicated but still easy to do. I've attached diagrams.
Most of the connectors for the CS alternators are four wire but you will only use two of them and the wiring is the same as the SI.
S = a heavy gauge wire to the battery supply (horn relay)
F = not used
L = a small gauge wire that comes from the idiot light and energizes the alternator
P = not used
Hope this helps you out
ID:	70571   Click image for larger version
ID:	70572   Click image for larger version
ID:	70573   Click image for larger version
ID:	70574   Click image for larger version
