CS130 Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2007, 07:37 PM
CS130 Wiring
I have installed the GM Serpentine belt system which is based on early 90s TPI engine, and the installation sheet refers to 1991 or 92 Camaro book for further reference. The alternator part # is GM 10463172 and is called in the instruction sheet "Delphi Delcotron, CS130 series generator assembly"
I am wiring from scratch with a "It's a Snap" wiring harness by Painless.
How do I wire the alternator?
Thanks in advance for any assistance, I researched the knowledge thread and did find some information, however the schematic would not come thru.
Thanks
Randy
Old 05-01-2007, 11:13 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-02-2007, 08:51 PM
CS130 Wiring
Doc.
Thanks for the reply
Just to make sure I understand, I will take the wire labeled EXCITER to the F terminal.
I only have a voltmeter with my Dolphin 5 inch quad set gauges(for 52 chevy pick-up).
I will make sure with a meter the EXCITER wire is 12 volts, with my ignition switch in the Start/ON position. Is this correct?
Randy
Old 05-03-2007, 12:26 AM
docvette's Avatar
Wiki Edits: 12
Originally Posted by Blaster
Doc.
Randy
Doc here,
If the wire marked Exciter has switched 12 volts on it , yes, that will go to F.
Since you have no lamp, L will not be used, or used with a resistive load.
Doc
Innovations
1 more cs130 wiring question 84cutlass Electrical 6 07-14-2006 05:48 AM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
