CSB oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2009, 06:27 PM
CSB oil pan
Will a 327 oil pan with a driver side dipstick fit a 350 with a drivers side dipstick? I am wondering if the crank journals will have an effect on the swap.
Old 06-10-2009, 06:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes. Check to see that you use the correct front seal.
The size of the seal you need to use depends on the pan. Measure down from the mounting surface where it bolts to the block down to the deepest part of the seal flange.
2 1/4" = thin seal
2 3/8" = thick seal
EDIT- You'd be doing yourself a big favor to use studs in the corner positions- especially if the engine's in the car.
SBF Oil Pan Gasket Problems coda618 Engine 12 04-14-2010 05:11 PM
Oil Pan Help Big Block Chevy 454 71 nova Engine 0 08-18-2008 09:51 AM
Z-28 Windage Tray / Oil Pan Clearance Issues ezobens Engine 1 03-25-2007 01:48 PM
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 06:33 PM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 01:32 PM
