cubic inch formula - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2005, 06:16 PM
cubic inch formula
Can someone tell me the formula for determining cubic inch size of an engine? I,m trying to figure out the exact size of my "40" over 327 SBC.
Old 04-15-2005, 06:19 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Bore X Bore X Stroke X .7854 X # of cylinders = Cubic Inches
Old 04-15-2005, 06:44 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
If your ever in a bind go HERE
327 was the same as a 350 it just useds a 3.25 inch stroke crank instead of the 350's 3.48. So in other words org. bore is 4 inches 4 over gives you 4.040 Then if you look on the page you wil lsee 40 over next to 327 and you will see 333.293... and there ya go
Chris
Old 04-15-2005, 07:40 PM
Max Keith's Avatar
Basic Math 101
Formula for finding CID of an engine.
Pi times bore radius squared times stroke times number of cylinders.
Example:
3.1416 X (2 x2 radius of 4 inch bore squared) X 3.50 = 43.98 X 8 = 351.86 Cubic Inches.
Old 04-16-2005, 08:25 PM
GoneNova/406's Avatar
example 350 c.i.
4x4x.7854x3.48x8=349.84857
borexborex.7854xstrokexnumber of cylinders=c.i.
Old 04-16-2005, 09:06 PM
NAIRB's Avatar
The volume of any cylinder is: PIE ARE SQUARE TIMES LENGTH. PIE ARE NOT ROUND IN MATH. PIE IS ROUND AT THE GROCERY STORE.
Of course the length in an automotive engine cylinder is determined by crankshaft stroke.
Who was asleep in 9th grade geometry?
Old 04-16-2005, 09:11 PM
Max Keith's Avatar
Geometry?
Gee I was taught the formula for finding the volumn of a cylinder in 6th grade math class, but then that was back in the days when teachers could read and write better than that students.
Old 04-16-2005, 09:34 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Good call brian. Not to be a jerk (heck, we've all made some poor calculations in our time) but for crying out loud, finding the volume of a cylinder is pretty basic stuff. After having been through basic high school algebra, we all should be able to do this stuff without needing 10 replies to give directions.
The proper way to do it is Pi(radus squared) mulitplied by stroke (or height of cylinder) and then by the number of bores you have.
K
Old 04-16-2005, 09:39 PM
One more way:
Area of the circle,times height. Paulo
305 cubic inch motor question richardson110 Engine 15 02-09-2008 08:53 AM
9 inch question 19nova72 Transmission - Rearend 7 03-12-2005 03:15 PM
mopar 500 cubic inch stroker zebber Engine 1 01-30-2005 10:31 PM
9 inch or 8 inch Cowtown Punk Transmission - Rearend 3 08-13-2004 08:10 PM
Cubic Inch and Cam Question tommytempest Engine 4 08-05-2004 08:39 PM
